Pin location
Robert (tnn)
05-27-2003 17:55:43
When hooking up bushhog what is proper hoie to use
lower or middle,for top link.Thanks
Dell (WA)
05-27-2003 18:26:12
 Re: Pin location in reply to Robert (tnn), 05-27-2003 17:55:43
Robert..... ...respected N-Authority, Palmer Fossom sez: "NEVER, EVER, hook anything to the 3-point tophole under your seat, it'll pull the guttz outta yer tractor".
The 3-points connection act as mechanical amplifer to the hydraulic lift. Top is MAX volume. Plows use the BOTTOM, brushogs use the MIDDLE and NOBODY uses the top link. Well you would if you were runnin' weeding shovels between corn rows..... .....Dell
Jerry Wi
05-27-2003 18:25:52
Robert, Use the bottom pin location. I can't remember which one but, one of the more knowledgeable members of the board, warns never to use the top spot on the three rocker arm. As Hyd. pump damage my follow. Good Luck.
