(OT) Pole ban building questions
Jake
05-29-2003 11:59:38
Getting ready to do this myself and wonder if you could answer a few
questions...
1. How do you erect the poles w/o a boom or some such device? Can it be done by hand? I have about 12 16-18' poles I need to put up.
2. If you don't use metal siding, what do you do about something like T-111 where it gets close to the ground? Is it ok to just attach it directly to the splash block?
3. Someone gave me those round chemonite treated greenpoles. Is it going to be difficult getting the side girts to line up on them; i.e. should I
just get rid of those even if they were free and buy 6x6's instead?
4. (Most important) Is it possible to build this thing by myself, with maybe my wife helping? It will be a 24x24 most likely, probably a lean-to type roof, but maybe a gable roof with trusses.
Thanks for any help!
Jake
Rickstir
05-30-2003 10:40:00
 Re: (OT) Pole ban building questions in reply to Jake, 05-29-2003 11:59:38
Have you built many barns? I'm not saying it is rocket science but at the height you are talking about it is no walk in the park either. Ever work, 16 feet off the ground, on something that is not rock solid, and try to push/pull/lift and hammer? It looks easy when an expert does it, but if your not experienced you could kill yourself very quickly. That's the question you need to ask yourself, is it worth it? I can put poles in and square them up, but I will not do the high work, I farm that out.
Bill(NC)
05-30-2003 03:39:30
My neighbor and I have built several pole barns from telephone poles (free from power co.). About 15 to 17 ft. I'm not saying this is the best way to get the pole in the hole, but it's quick.
We use his JD with a boom. Tie a chain about mid way of the pole, so that one end just barely tilts to the ground. I hold the pole off the ground, and we position it over the hole. I put a strip of sheet metal on one side of the hole to avoid pulling in dirt with the pole. He pulls forward while I guide the pole into the hole. You have to be careful that the pole does not sway to the side, but it does not seem to be a problem. The side away from the sheet metal, and toward the tractor, will scrape about a foot of dirt into the hole. Takes about ten minutes per pole.
Crockett
05-29-2003 18:57:21
Jake:
I built a 30 x 40 pole barn last summer. It's a great work space. I used PT 16' 6x6 corner posts and 16' 4x6 intermediate posts spaced 8' o.c. I have 12' 6" head room to accomadate tall vehicles.
Dug all the holes with a neighbor's post hole digger on the back of a big John Deere. I set the poles with help from a few friends. Tip: place a saw horse about eight feet from the hole. Place a 2x4 that will extend to either side of the hole on the flat next to the hole and stake it down (I drilled a hole in each end and used a 60 D spkike to keep the 2x4 in place). Place your post on the saw horse and 2x4. Have a couple of helpers lift it in place. Check for square and back fill. I used 32' 6" pitch trusses for a clear floor space. Putting up the trusses was a bear. Six friends and good staging got the job done although I would consider a crane next time. As to siding if you price it out metal is the best deal. T-11 needs more framing and you have to paint / stain it. A great reference for pole buildings is "Low cost pole building construction: the complete how to book" by Ralph Wolfe, published in 1980 by Storey Cummications, Inc. Pownal, VT 05261. It has a major focus on using round poles like old telephones poles rather than on using dimensional lumber. I hope this helps!
Gary 8n Fl
05-29-2003 18:17:45
Well, just built a pole barn about a month ago.
I had some old telco poles laying about so I used them. All I had was a few 2x4s(later used as roof trusses), rope, a chainsaw, post hole digger and a shovel.
I made a gabled roof on my barn/shed. 4 foot higher at the center than the ends, a 21x22ft building in all, using 12ft metal roofing.
To place the poles I dug down 4 to 5 ft w the post hole digger, used a shovel to slope one side of the hole. I rolled the pole over the hole (18 fter), Put 2 2x4s standing up in the back of the hole so it would not collapse, and pulled it pretty much upright using my ATV, rope and an aframe setup. After its standing it will be easy to hand push it pretty much upright. Fill it in adjusting as you go, tamp etc... worked well.
After I measured and used the chainsaw to notch out the tops for my 2x6 stringers, about an hour per pole after I got it down. Of course we have only sand in these parts, no rocks to fight with.
BTW 1.Use a sturdy a-frame. 2.Its easier to line up the pole on the ground if you use 2 2x4s as rails to roll it on, and this helps to prevent premature hole collapse also.
Brutus
05-29-2003 15:31:08
i just hauled a load of free poles to a neighbor
that has a bandsaw mill,brought back a load of 6x6
poles that look just like the real thing,fraction
of the cost of new,light enough to handle, easy to line up and nail.
-brutus-
duey
05-29-2003 15:27:14
Jake, if you are in deep frost country, my free advice would be to pour a floating slab, then go up with 2 X 6 walls... then setting the rafters or trusses would be the hardest lift.... and 24 footers aren't too bad to do. Bonus: no holes to dig, and it is so nice to work off that new slab! Good plan would be to round up some extra manpower for the rafter day... 6 adults makes it go good. Price it out both ways... you may be surprised. Take lots of pictures and have fun. duey
buck
05-29-2003 17:33:06
 Re: Re: (OT) Pole ban building questions in reply to duey, 05-29-2003 15:27:14
I agree with your line of thinking here and in fact if he goes with the t-111 sideing that is going to require almost enough framing as it would be to just stud up the walls. I see no reason that a 2x4 stud wall wouldn't work though unless there is some load/code/insulation that I am not picking up on. In fact when using t-111 and no concrete floor/footings I think it is simpler to plant short poles with the tops just above ground level,place what you would normally use for headers and go up from there with a normal stud wall. anyway all have fun.
Rob
05-29-2003 12:41:00
All the pole barns herebouts are built with poles. FYI, you can buy a boom pole for your 3pt for around $50 new. I don't know if you gain all that much but you could lift those poles at maybe 5' or so. Stick em in there without breaking a sweat.
I guess you make the outside edge of the pole plumb. I never really looked at it but that would make for a plumb outside wall. You don't want to see the siding right on the concrete. Generally the siding laps the concrete. That keeps the rain out. Anytime you lay or butt wood or metal to concrete you want to think about a moisture barrier anyway.
Pay attention to getting the corners square and it will make things a lot easier.
souNdguy
05-29-2003 12:32:48
With only 16 - 18' poles, I would imagine with a little ingenuity and some gadgetry you and your wife could do it... though a gable or trussed roof might be easier with a crane.
A lean too or flat, swept back angle roof would be a piece of cake to frame around, add the purloins and tin.
If you feel froggy.. and the poles are free go for it.... if you use the wood siding, and it isnt perfect, use runners or firing strips to shim it up... it's a barn right? I've seen hundreds of telephone pole - pole barns.
For the union of the bottom plate and siding, etc.. you will already be using PT wood anyway.
It wouldn't hurt to add a little extra treatment .. like water shield, etc.
Probably wouldn't hurt to termite pretreat the area either. Iv you have a local 'kill it yourself' pesticide store, you can buy products like demon, ground stable permethrin, or sentry and apply it yourself.. all three are professional grade termite treatments. In lieu of those, I would at least hit the areas with a good saturated coat of farm mix emulsion type permethrin ( not ground stable for more than a couple weeks ) and then do 'booster' applications every couple months around the perimeter to stave off termites, ants.. or any other insects you don't want in the barn.
I don't know how heavy the piles you will be setting are, but if you dig the footer holes and a sloped entrance to the hole, you and a neighbore should be able to manhandle them in place... I set some 18' 4x4's by myself.. two guys should handle a pole fairly well.
Lots of 'helpers' can be fabricated to help you set these poles. Small 'A' frames, "H" frames as props for tipping the poles up and over the fulcrum (pivot point).. etc.
Make the best use of legerage and mechanical advantage whenever possible.
I often ( read: always ) have to build the farm stuff myself... The lit riding areena with the lights on the poles... miles of plumbing and electric, various and sundry animal pens, free standing horse stalls and shade structures out in the pasture.... you get used to figuring out how to do it with ropes, pullies, braces, 'dead men' the tractor and boom pole... extra ladders.. etc...
Tamp frequently as you fill the piles footers.. ( I.E. don't fill them completely then just compact the surface.
Concrete shouldn't be needed around the friction pile, though a flat block is usually thrown in the bottom.
Good luck and be safe.. if the job gets to the point that you feel that it is unsafe, get a crane or hire it out.
Soundguy
chuck
05-29-2003 12:19:16
Jake, My wife and I built a 36 x 24 pole building. The only help we got was I hired a roofer to lay the asphalt shingles. I was getting tired and rain was coming. I used 6"x6"x12's. We dug the post holes and were able to stand the poles up in the holes with just "back power". I built a gable roof on top that used truss-type structure-makes a nice attic now.
chuck
436244
Duner Wi
05-29-2003 12:12:23
#3 There were round poles before there were sq. poles. Lots of sheds built with round poles. Take a look at a couple to see how it is done. Not that difficult. I always thought a round pole was stronger than a sq. pole.
