Mastinox Anti-seize
Rick
05-30-2003 06:57:33
I'm getting ready to reassemble the rear-end of my 8N. A friend of mine is an aircraft engine machanic and has given me a container of anti-seize compound called "Mastinox." It is a bright-yellow, grease-like compound that he says will allow no seizure - ever. Should I use the stuff to coat the trumpet to center housing studs or should I be using something to lock the studs, like loctite?
Snader
10-15-2006 19:57:28
 Re: Mastinox Anti-seize in reply to Rick, 05-30-2003 06:57:33
Hi rick, If I were u I'd get a big plastic bag and some really thick plastic gloves and throw the mastinox out.
That stuff is very dangerous, don't touch it lick it or inhale it. It's illegal for us to use it nowadays, even in aircraft maintenance it's banned.
check out more aircraft related info at my website:
Link
Lee
05-30-2003 10:17:31
I'd say no to both questions. If ya got it apart in the first place ya probably don't need anti-sieze and I don't think loctite is necessary. My opinion and you know what they say about opinions.
Good Luck, Lee
duey
05-30-2003 07:45:39
Get and read an MSDS sheet on MASTINOX before you get it all over you. I understand it *IS* good stuff. But I think it is "fair to poisonous"... learn about it then make use of it when you know about it. duey
michele
10-18-2005 09:27:54
 Re: Re: Mastinox Anti-seize in reply to duey, 05-30-2003 07:45:39
My husband works in the aircraft industry and was exposed to Mastinox , he had a yellow greasy substance on his hands, didnt really know what it was, wased his hands then ate his sandwhich later, which left a nasty taste in his mouth, he reported this to his sup. and was sent home to soak his hand in warm soapy water. I saw where you said it was poisonous. If you have any info on this would you please e-mail me.
Thank You , concerned wife.
MikeTheMech
11-01-2006 09:07:34
 Re: Re: Mastinox Anti-seize in reply to michele, 10-18-2005 09:27:54
Mastinox contains hexavalent chromium. Go to this page to find out more of the hazards:
Link
It is still in use in aviation maintenance, the effects of the product are known, but not by the people using it because they don't read the MSDS. This isn't good stuff.
the AME
05-08-2007 12:48:24
 Re: Re: Mastinox Anti-seize in reply to MikeTheMech, 11-01-2006 09:07:34
we still use this product in Aerospace and it is very toxic, I would do as previously mentioned, dispose of it properly!!!
