Trumpet to Center Housing Gasket Sealer?
Rick
05-31-2003 09:45:40
Should I use a gasket sealer on the gasket between the axle trumpets and center housing? Also, what torque should be used on the trumpet studs? Thanks in advance.
Ken/Wa
05-31-2003 18:41:18
 Re: Trumpet to Center Housing Gasket Sealer? in reply to Rick, 05-31-2003 09:45:40
I did mine a couple of summers ago, and wanted to put sealer in mine also, but did as Dell has suggested, and it has not leaked. Must be the good maching done on these old tractors. I think the torqueing is important.
Rick
06-01-2003 03:45:53
 Re: Re: Trumpet to Center Housing Gasket Sealer? in reply to Ken/Wa, 05-31-2003 18:41:18
Thanks to you both. It's no sealer for me.
Dell (WA)
05-31-2003 10:04:36
Rick..... ...wipe your paper trumpet gasket with warm water and torque the 7/16 trumpet studs to 55 ft/lbs..... ....Dell
