Stupid Tractor Operator Tricks
Pitch
05-31-2003 18:43:41
Well I did the ultimate in stupid things today, I am so ashamed of this act that I normally would never mention it but maybe someone can benefit from my error. I was doing a bit of landscape work this morning and it was a bit on the chilly side so I was wearing a long sleeve shirt. Couple hours later it warmed up so I pulled the shirt off, laid it on the seat sat on it and went back to work. You guessed it bout ten minutes later the PTO caught on of the dangling sleeves, Snatched that shirt from under my butt liketey-split almost took me with it. These machines are killers don't ever turn your back on them cause they don't care. One second of thoughtlesness could have really hurt me I was lucky. Went in the house changed my shorts had a cup of coffee kissed the wife and kids and then spent about twenty minutes with a pocket knife and pry bar untangling the mess. Please be careful
Dave Todd
06-01-2003 15:38:09
 Re: Stupid Tractor Operator Tricks in reply to Pitch, 05-31-2003 18:43:41
For myself, this is one more reason I want to buy the live hydraulic kit from Zane. Most of the time I use the hydraulics, but don't need the PTO unless I'm mowing. I see Zane's kit as a way to save wear and tear on the PTO parts and pump, and possibly myself, especially when I don't need to use the PTO for anything other than running the pump. I still would recomend a PTO cap. And ALWAYS try and use common sense on these machines.
Glad you're okay!!!!
Dave
Rich, NJ
06-01-2003 05:50:43
Many years ago I was setting up my JD model 30 Combine on ther PTO of my Farmall H. Don't ask me how it happened , it was all too fast. Somehow my pant leg (Dungarees) got caught on the unversal of the Combine's drive shaft. I couldn't reach the switch or the PTO lever. It was turning and the tension on my leg was increasing fast! Then a strange thing happened. My pant leg exploded, Literally! It made a loud sort of a banging sound and completely tore off my leg. The pants were ruined, but my leg was ok , but it was red for a few days after. I believe they snagged on the zerk fitting on the universal. Regards, Rich
MikeC
06-01-2003 04:24:07
At least you didn't tie it around your waist like a lot of kids do!
Fast Ed Ohio
05-31-2003 22:41:28
You were lucky, Ive heard of fellas being snatched ball headed, armes torn off, legs torn off, and worse, these old tractor are machines ,they will chop you up just like a clump of grass and not even say Im sorry, gots to be more carefull out there, glad your ok .
Tyler (MD)
05-31-2003 20:52:03
Glad you're alive and not hurt. I new a farmer down the road wasn't so lucky. Hauling manure in a spreader, he was driving his tractor too close to the side of bank and the tractor and spreader/manure tumbled down the hill and landed on top of him. I think the tractor was a Farmall. He lived for awhile but died later. I knew him, his daughter and son.
There's always a lesson to be learned. Accidents happen. Just be safe and use common sense.
One of the saddest posts I read here at the board was the Farmer(GA) post. He loaned his 8N to his neighbor. An hour later the neighbors kid came to him screaming that his dad was pinned under the tractor. He was trying to pull a tree down that had fell and lodged into another tree. He was using the top link area to pull from instead of below the rear axle that your are suppose to pull from. The tractor flipped over onto him and killed him. The owner of the 8N had trouble dealing with it.
I told this story to my brother who had just acquired a new 4x 4 JD tractor. He never knew you weren't suppose to pull from a position about the rear axle to avoid a flip over.
Lessons learned all the time.
Tyman
Vic (I hear ya!)
05-31-2003 20:18:47
A few years ago, I made the decision to go to a quick-connect overrunning clutch for pretty much that reason. My rule that if I'm using any non-PTO 3-point implement, the ORC comes off and the PTO cap goes on. Always.
I made this decision after I was using my 3-point scoop with a rope to the release lever. It suddenly occurred to me one day that when I needed to pull the release real hard, I'd tend to wrap the rope around my wrist for a better grip. I noticed that the extra rope was dangling from around my wrist to within an inch or two of the spinning PTO, and that became an INSTANT safety education. It was at that moment that I decided on my new PTO cap policy, and I've stuck with it ever since. And no, I never wrap the rope around any part of my body any more either.
don t. - 9n180179...Yes s
06-01-2003 03:15:58
 Re: Re: Stupid Tractor Operator Tricks in reply to Vic (I hear ya!), 05-31-2003 20:18:47
I do the same thing! I was lucky enough to have the original PTO cover when I bought it. I don't use the PHD much anymore, the bush hog twice/year. It just makes sense to cover the moving part(s) when possible.
I got the following in email from a friend awhile back:
Common sense is very uncommon.  Common sense is in spite of, not as a result of education.  Common sense is instinct, and enough is genius.  Nothing is more fairly distributed than common sense:  no one thinks he need more of it than he already has.  Common sense is the knack of seeing things as they are, and doing things as they ought to be done.
FWIW....don t. ....
markct
05-31-2003 20:18:36
sounds like ya gota get yourself a pto shaft cover
Buckeye JIm
05-31-2003 19:02:30
Thanks for sharing this story !
We all need to keep safety on our minds.
Remember SAFETY HAS NO QUITTING TIME as we say at work.
