Misfiring
Ralph MO
06-01-2003 13:52:36
8-N Newly rebuilt motor, rebuilt carb,new plugs, points,condenser,rotor, dist. cap, coil,new wires in the right order 1-2-4-3 (Dell), getting plenty of new fuel to carb. Does not help to adjust carb. Does not help any to mess with timing. Idles pretty good, surges and misses at higher rpms and will not pull a load??? Lets try again, any ideas!! Thanks!!
Dell (WA)
06-02-2003 06:06:22
 Re: Misfiring in reply to Ralph MO, 06-01-2003 13:52:36
Ralph..... ....you write "Idles pretty good, surges and misses at higher rpms and will not pull a load???" Sounds like a governor problem to me. Have you checked? Simple to do. DISCONNECT eather springloaded end of the carb throttle shaft to governor lever while engine is idleing. Then jazz your motor by hand to high rpms. If still missing, its not your governor, its your sparkies..... ..... Dell
Fast Ed Ohio
06-01-2003 23:51:20
If the camshaft was replaced, I understand the timing markes are out of whack on some of the new ones.
Larry
06-01-2003 15:45:11
What Swavo said - however surging (or hunting) with your description would indicate a vacuum leak. Either from the carburetor to the manifold or more likely from the manifold to the block. Surging occurs generally when demands are placed on the engine, rpm's rise which (and if a vacuum leak) causes the fuel to be mixed with outside air and thins the mix. The engine and governor can't cope with this mix as it isn't combustible enough for efficient operation. When the tractor then looses rpm's from this - then it will pick up speed when the rpm's drop (lower vacuum) but when it tries to regain the set rpm the cycle starts all over again.
Regards,
L and C Ranch
DON TX
06-01-2003 15:37:03
My WAG is check your points gap. Mine closed up on me and gave pretty much the same symptoms you have. Cheap and easy to do. HTH
DON TX
swavo
06-01-2003 15:09:32
sounds like weak spark (bad coil), or the centrifical advance could be sticking.
Mike
RalphMO
06-01-2003 17:40:49
 Re: Re: Misfiring in reply to swavo, 06-01-2003 15:09:32
What and where is the centrifical advance, how do you un-stick it?
Scott
06-01-2003 20:37:28
 Re: Re: Re: Misfiring in reply to RalphMO, 06-01-2003 17:40:49
The advance should be the plate that the points mount to. You should have a spring on it to pull it back to idol possition. That plate should twist some.
