6 v positive ground oil screen
Pat
01-07-2001 11:16:54
Guys, I have two questions, where did the short, flat grounding strap terminate on the tractor orginally? Also, I saw on a tuneup video, a screen on top of the oil drain plug on the 9N. Is it needed as I don't have one on my 40 9N.
Thanks
Pat
norm-wy
01-08-2001 11:34:41
 Re: 6 v positive ground oil screen in reply to Pat, 01-07-2001 11:16:54
Pat
The ground strap attaches to the rear of the steering/dash support. If I'm not mistaken, there is a tapped hole for the mounting bolt, but remember free advice is only worth what you pay for it.:-)
Bill
01-07-2001 15:49:16
Pat,
The screen should be there (at least on an 8N and I think on a 9N). It makes sure no large particles or sludge chunks get into the oil pump pickup tube. Its like an oil prefilter.
Hope this helps,
Bill
TimK
01-07-2001 17:35:12
 Re: Re: 6 v positive ground oil screen in reply to Bill, 01-07-2001 15:49:16
I believe that the screen also acts as somewhat of a stabilizer for the oil pick-up tube, which has a tendancy to viabrate and crack.
don b
01-08-2001 15:28:09
 Re: Re: Re: 6 v positive ground oil screen in reply to TimK, 01-07-2001 17:35:12
Both posts are correct and they were on the 9n. don
