(OT) What does a capacitor do?
tom
06-02-2003 07:40:15
What does an electric motror capacitor do? how does it work? and if I run 220v through a 100 capacitor, run the motor, turn it off and it goes poof as the motor is winding down did I cook the motor or capacitor?
hrt
03-03-2006 01:19:59
 Re: (OT) What does a capacitor do? in reply to tom, 06-02-2003 07:40:15
rtujhrtjtjtrtjry
craig barton
03-03-2006 01:13:25
i need cock
Catherine Cuttrass
04-10-2005 19:39:20
Kewl.Copacitors Do Tons
Rob
06-02-2003 15:22:23
A cap stores an electrical charge. It is use when 'time' is an issue. It takes 'time' to charge a cap and 'time' to discharge a cap. In your distributor they put in a capacitor so that you get a spark that lasts for some 'time.' Instead of an instant very hot spark you get a spark that lasts for some thousandths or even millionths of a second. The motor thing uses a cap to phase shift or 'delay' the electricity just a bit so the motor actually has the same volts hitting it at slightly different times. It gets two jolts for every AC jolt. Generally from different directions, or different windings. Amazing huh? Caps are all about 'time.'
craig barton
03-03-2006 01:17:26
 Re: Re: (OT) What does a capacitor do? in reply to Rob, 06-02-2003 15:22:23
i dunno but i need sum cock
Rick H. Ga.
06-02-2003 11:04:45
Hi Tom,
Some single-phase motors use capacitors to aid in motor starting and running efficiency. There are two kinds of electric motor capacitors, a run capacitor and a start capacitor. Both are wired in series with the start winding of the motor. The run capacitor stays in the start winding circuit continuously to aid in starting and running efficiency (this is why it is called a run capacitor even though it is wired into the start winding circuit) but the start capacitor must have a means of opening the circuit to the start winding such as a potential relay, a current relay, or centrifugal switch once the motor has started and reached about 75% of full speed.
Start capacitors usually have a round black plastic housing with two terminals at the top and run capacitors are usually an oval shaped aluminum metal housing with two terminals at the top. You must use the correct capacitor for the motor to work right. The data plate on the motor should state which capacitor to use. Capacitors are measured in voltage (usually above 300V) and microfarads (uf) which is the strength of the capacitor(could be 5uf to 50uf or more depending on the motor).
The capacitors create a phase shift in the AC sine wave that causes the start windings of the motor to have a better starting torque and more running efficiency. HTH. Rick H. Ga.
Ed S. (IL)
06-02-2003 09:13:51
Here's a description of how a capacitor works:
Link
My guess (emphasis on GUESS!) is the capacitor blew...
es
steve m
06-02-2003 08:34:34
is that a 100V or 100uF capacitor? It is an AC motor, right? was the cap in series or parallel?
