Rear wheel studs
Ron
06-02-2003 13:47:22
I need rear wheel studs that hold center to brake drum on 9n. Someone please tell me where I can get them. Just 8n's does not have them for a 9n. They are 5/8 - 18 thread.
Scott
06-02-2003 17:58:45
 Re: rear wheel studs in reply to Ron, 06-02-2003 13:47:22
Your local New-Holland dealer has them, there is a swedging tool they can use to make them fit tight in the axle so they do not come out when you put the wheel on.
don b
06-03-2003 10:16:12
 Re: Re: rear wheel studs in reply to Scott, 06-02-2003 17:58:45
I called local N/H dealer and they wanted 11.00 and some pennies for each stud. don b
Ron
06-02-2003 15:34:25
 Re: Re: rear wheel studs in reply to Dell (WA), 06-02-2003 15:27:30
Thanks Dell. Problem is the shoulder. Have located standard wheel studs with correct thread and length but wrong size shoulder or correct shoulder but 11/16 - 18 thread. May have to find someone with a lathe.
Dell (WA)
06-02-2003 15:45:14
 Re: Re: Re: rear wheel studs in reply to Ron, 06-02-2003 15:34:25
Ron..... ..what wrong with going with the slightly larger diameter stud with correc sholder? Altho a good lathe guy could cut the 11/16 down to 5/8 and you'd be good to go. its your dollar (mucho dinnaro)..... ..Dell
