Broken
Lower Link Shaft
Phil
01-07-2001 14:44:09
Does anyone know where I could get one . Part # 9N-563 , 7/8 inch diameter going through rear axle housing. Thanks
Phil
01-07-2001 17:48:02
 Re: Re: Broken - Lower Link Shaft in reply to Scott, 01-07-2001 16:47:31
Thanks Scott, But do they carry 9N-563 because 8N's are NCA-563-C
Old George
01-07-2001 19:46:04
 Re: Re: Re: Broken - Lower Link Shaft in reply to Phil, 01-07-2001 17:48:02
third party image
Phil, not to worry, Scott is correct. This is the one you need the straight one. The 8N one is tapered. Don has both. I believe the gaskets are different too. Hope this helps.
Alan Esch
45 2N kit 183513
Scott
01-07-2001 18:08:42
I bought one from him for my '41 9N. I havn't installed it yet, but I'll run out and check it. I already have the rear end off my tractor, so I'll post back later tonight.
Scott
01-07-2001 18:29:06
 Re: Re: Re: Re: Broken - Lower Link Shaft in reply to Scott, 01-07-2001 18:08:42
Phil-
I went out to install the new pin, but I have to have the old one pressed out from its mounting plate tomorrow. The new one looks identical, and They are the same diameter and length.
Scott
