OT: What's Your Favorite Rust Preventer?
Arhtur Brestlin
06-03-2003 16:47:45
After an unending Winter, NY state is having a God awfull Spring! It has been raining since Ike was a Cadet! I can't mow or plant or spray or do anything but watch my old iron rust before my eyes. I am concerned that my gang mowers, which are too big to move into the barn, will be rusted into a solid one piece paper weight! I have sprayed them with both kero and diesel, but they don't last very long. What would you suggest as either a brush on or spray on protection from these adverse climate conditions?
Hal/WA
06-04-2003 18:54:13
 Re: OT: What's Your Favorite Rust Preventer? in reply to Arhtur Brestlin, 06-03-2003 16:47:45
You might try grease, like normal chassis lube, applied with an old paint brush. The grease could even be contaminated junk that you wouldn't use for anything else. Grease takes a long time to wash off and unless the implement sits in the hot afternoon sun, will stay there for awhile.
souNdguy
06-04-2003 10:33:24
My first guess would be paint in combination with shelter from the elements...
As some pointed out, petroleum applications can be effective in the short term, but wash out quickly.. and you don't want to over do it...
Incedental oil dropped into the environment is just that incedental.. unintentional drips, or even non-significant leaks. The environment has a fudge factor to handle a certain amount of point and non-pont source contaminations... mainly the dilution factor...
Continual intentional application of fuel oils and such will eentually cause an environmental problem though...Keep in mind that a tablespoon of fuel oil can contaminate up to 2000 gallons of potable water. Also keep in mind that the EPA classifies waste oil products as 'hazardous'...
Not preaching at you, just making a bit of a point... there are much better and environmentally friendly treatments for old iron, and especially wood. Liquid asphalt emulsion paints cure to an environmentally inert level and are excelent wood protectors.
Only reason I climbed on the soapbox is that as a CE I usually get to see first hand what pollution ( in general.. not just petro-chemical ) does to the environment. ... ok.. off soap box.. return to normal programming..
Soundguy
James Scott
06-04-2003 05:04:39
It's not really a rust preventive and You will have to wait for it to someday stop raining. I took a rusty field mower apart over a year ago and Painted it with Por15..It's still semi apar and still in the weather and no rust is showing/
'52 8N (MD)
06-04-2003 04:55:06
Extend or One-Step both convert and encapsulate rust to a paint ready primer/sealer.
Fessman
06-03-2003 18:32:08
Krylon makes a rust preventative.
I have used the s00222 in the past, and it worked great. I left some stuff outdoors all winter, with no paint, just the rust preventative, and there was no rust in the spring. I do not think that they have the s00222 anymore. It appears that all they have is s00777. Give it a shot, the stuff does work great. If you need to find a place to buy it let me know.
The following link will take you to thier website:
http://www.krylonindustrial.com/index.html?session_id=6ac4bdea37b7cdfc7aa5d43b481cf3c4&screen=s00777_long_term_outdoor
Adam P
06-03-2003 17:47:14
I agree with Rob on this one. I use used motor oil and such. I use it with a brush, and spray it with a two gallon pump sprayer. I use it on outdoor wood, and outdoor implements.
Good luck
APAudVid
PS and a tarp is a good idea too.
you are delaying the inev
06-03-2003 17:15:46
I bet, the best thing you can do is to build a crate over them with a decent plastic tarp over the crate. just nail together some old pallets and drape the plastic over them or some scrap 2 by materials. Unless you remove the rust, and then prime and paint you will just delay the inevitable.
Rob
06-03-2003 16:53:31
I always have a bunch of crankcase oil and used hydraulic fluid around. Too much. I oil up my blade and such. You're using that thin diesel and kero maybe you can find a thicker mix with your waste oils. Or just oil that stuff up.
