Ron - PB Blaster, heat, finally a press. I cut the retaining collar off and drilled out the four rivets holding everything to the backing plate. Once I had the shaft and bearing block in hand I could get it in the press. For me the bushing came out with the shaft. The bushing wasn't that bad, just a rusting shaft binding everything together. Note that the shaft is 1" and then 1.0625" (me thinks) where the bushing rides. Clean it up, grease it up and back together. If you have the $ or resources you could build the shaft back up and turn it down. I didn't. :( I used socket head cap screws to mount the block back to the backing plate, heads out, but rivets could be found, and a 1" split shaft collar instead of the pinned original collar to retain the shaft. I placed a 0.25 inch piece of 1" ID X 1.25" OD (top link collar to shim CAT I to CAT II) to offset the split collar from the backing plate. That's what I did. One could skip cutting the rivets if you can get everything blocked properly for your press. I remember it being difficult with the backing plate in the way.
