Jump 6V with 12Vcharger?
8n34343
06-04-2003 08:02:48
I read a post awhile back about how you can jump a 6v system with a 12v if you hook it up a certion way.I can't find it in the archive however.Can anyone help me out?
duey
06-04-2003 10:30:50
 Re: Jump 6V with 12Vcharger? in reply to 8n34343, 06-04-2003 08:02:48
You've got the answer below for JUMPING the tractor using a 12 volt battery. For CHARGING a 6 volt battery with a 12 volt charger, me, I'd use a 6 volt headlamp connected in series with the battery being charged and just use my 12 volt charger. Not a perfect arrangement but could get you by on the odd occasion...a smaller lamp or bulb will reduce the charge rate.... duey
Gary_N_WV
06-04-2003 09:29:17
I picked up a 6v/12V charger at Walmart about 6 mo. ago for about 20 bucks....wasn't a real high amperage one on 6 Volt, but...hey....I'm in no hurry !
Bruce (VA)
06-04-2003 09:58:59
 Re: Re: Jump 6V with 12Vcharger? in reply to Gary_N_WV, 06-04-2003 09:29:17
Got a model number? My 6/12 charger is at least 30 years old..... ....
Gary_N_WV
06-04-2003 11:02:52
 Re: Re: Re: Jump 6V with 12Vcharger? in reply to Bruce (VA), 06-04-2003 09:58:59
I'll try to remember to look tomorrow evening when I get home for the model number.
Flea markets are also a good place to pick up 6 v chargers...I bought a Sears model....4 amp job for 2 bucks a couple weeks ago...had to replace the power cord though....but...it works great.
Bruce(VA)
06-04-2003 11:14:42
 Re: Re: Re: Re: Jump 6V with 12Vcharger? in reply to Gary_N_WV, 06-04-2003 11:02:52
Thanks!
Dell (WA)
06-04-2003 08:18:56
You place your tractor gearbox in neutral, throttle 1/3, ignition switch on. Connect negative side of a real 12 volt battery to the starter motor STUD and ground the battery POSITIVE to anywhere you can clamp. And crank-away.
I HAVE NEVER BEEN SUCCESSFUL using ANY CHARGER as a booster starter (even those labled as starter booster), they always barf their gutts and lett the smoke out. You do know electrical stuff runs on smoke don't you? Let the smoke out and they quit runnin'..... .....Dell
Evil Steve
06-04-2003 09:46:37
 Re: Re: Jump 6V with 12Vcharger? in reply to Dell (WA), 06-04-2003 08:18:56
I keep one that has a 6 and a 12 volt toggle with the jump booster. I've used it on Chigger and on my bay boat successfully. Cheap $40 Sears model. Gives just enough of a bump that a well tuned engine will start.
I didn't know-Dell
06-04-2003 08:28:18
Thanks Dell,I didn't know that electric stull run on smoke,but havin found out I think I'm gonna let the smoke out of this charger,I got ripped on this thing,it won't charge a 6V. only 12.
Rob
06-04-2003 08:34:17
 Re: Re: Re: Jump 6V with 12Vcharger? in reply to I didn't know-Dell, 06-04-2003 08:28:18
6v chargers can be hard to find but TSC has a 6v/12v charger for $25! I also got one of those 12v jump boxes for like $30 on sale. Love em both!
