Interchangability of a NAA Rear Housing Assembly
Roger
06-04-2003 19:43:41
Went to repair what I thought was a ring and pinion problem and it turned out to be a broken rear housing that caused the R&P to fail. The casting that broke is the internal portion that supports the pinion assembly. My question is: Will a rear housing from a 600 or 800 (4 speed)series interchange with the NAA? It might be easier to find one these as opposed to a 53/54 rear end.
Thanks
Tractor Rod
06-05-2003 04:06:45
 Re: Interchangability of a NAA Rear Housing Assemb in reply to Roger, 06-04-2003 19:43:41
Roger the NAA housing is all by it's self. The 600 or 800 housing won't interchange because of the hyd line setup. Tractor Rod
Jim.UT
06-04-2003 20:14:51
I believe the 600 housing is different than the 800 housing. If either of them interchange with the NAA I would guess it would be the 600. Have you tried tOTG?
