Position control rocker
Rob
06-05-2003 06:16:14
'51 8N. If a guy was hogging with position control what would he lose by connecting the top link to a pin there where the (missing) rocker arm normally connects to the differential housing? The control spring would just be hanging there connected only on the one end.
How 'bout a blade?
How 'bout a boom pole?
Is that spring there for anything but draft control? Is it necessary for position control?
ZANE
06-05-2003 07:24:12
 Re: Position control rocker in reply to Rob, 06-05-2003 06:16:14
That spring is only there for draft control.
It would not have any effect on the lift if the top link were connected rigidly to the rocker hole.
However if this hole is damaged or broken off then you are going to be in for a lot of grief.
Rob
06-05-2003 07:57:18
 Re: Re: Position control rocker in reply to ZANE, 06-05-2003 07:24:12
Yeah. Good point. Thanks for the comeback.
