Tranny Oil
Ralph MO
06-08-2003 07:59:37
Which tranny oil should I use in 8-N 1950. Thanks!
Adam P
06-08-2003 11:24:08
 Re: Tranny Oil in reply to Ralph MO, 06-08-2003 07:59:37
Use regular 90w mineral oil. It has to conform to GL1 spec. I've used NAPA part number 65-205. It's got a great price, and it's the right stuff....
Do not use other GL numbers (like 3, 4, or 5...)
they will ultimatly ruin the seals.
AP
Rob
06-08-2003 08:58:49
The fluid mentioned in that first post is the fluid sold for equipment that uses the same sump for transmission, rear end, and hydraulics. Some equipment does not have a common sump and does not use the same fluid for all those things. You will generally find the fluid sold for common sump equipment meets Fords MC134-D. I think it's -D. Maybe it's -C. Anyway, its the fluid sold for common sump equipment.
Some guys try to stay with the original recommendation of mineral oil. Thinned with kerosene in the winter. Or some such...sounds like a pain to me.
MikeC
06-08-2003 12:57:18
 Re: Re: Tranny Oil in reply to Rob, 06-08-2003 08:58:49
It's a "D". The D stands for "Defense". It meets Department of Defense specs. Or so I've been told.
Rob
06-08-2003 12:59:43
 Re: Re: Re: Tranny Oil in reply to MikeC, 06-08-2003 12:57:18
I never can remember so I just look for the stuff that works for common sump equipment.
KWP
06-08-2003 08:22:56
FORD RECOMMENDS THEIR 134 TRANS HYRDO
