Stay chains
Robert Tnn
06-08-2003 08:01:09
What are the pro and con for using stay chains(top link to hog).I have two stab bars on 8n.
I made up the stay chain,have not used the bushog
yet Thanks for inf.RobertTnn
Dell (WA)
06-09-2003 02:39:58
 Re: Stay chains in reply to Robert Tnn, 06-08-2003 08:01:09
Robert..... ...even though the 8N has "position control", I recommend using the height controlling stay-chains for 2 reasons. 1) takes the weight off the hydraulic's.
2nd reason is chains collapse when you raise the hydraulics to go OVER an obstical and will automatically return to your chain pre-set mowing height and you don't have to worry about lookin' behind ya an wonderin' if you're mowing at the right height.
I also recommend you continue to use the stabalizer bars from brushog's lower link pins back to under the tractors fender mounts..... ...Dell
Rob
06-08-2003 08:24:11
If you rig chains then the hog isn't laying in the gravel when you engage the blade. I like that a lot.
