Rebuild question
russ
06-08-2003 08:19:04
i had the crank turned on my 8n and the rods came out to 2.075 and the mains at 2.230 .the engine has the distributor in the front.i want to know what oversized bearings to order?thanks for any help
JimNC
06-08-2003 10:37:54
 Re: rebuild question in reply to russ, 06-08-2003 08:19:04
It looks like your conrod and crank journals have been turned to 0.019" undersize so you will need 0.020" undersize bearings.
Jim
Claus
06-08-2003 10:15:41
I don't know who you deal with, but when I send a crank out for machining, it comes back with the correct size bearings.
Happy Motoring
Claus
Rick H. Ga.
06-08-2003 09:42:00
Hi Russ,
Usually, the crank shaft is turned to fit the demension of the next avaliable size bearing (in increments of ten thousandths of an inch). However, I have heard of ordering non-standard size bearings.
Jim is correct, check with a good parts supplier. (Whoever turned the crank should have provided you with this information) HTH. Rick H. Ga.
Jim
06-08-2003 09:09:49
I would ask someone who sells the engine rebuild kits/bearings.
If they are truly a good supplier of parts they will know.
Jim
