Governor leak
Pj 8n Wy
06-08-2003 22:25:11
Any one ever fix an oil leak on the governor where the oil line elbow comes out of the housing? ie: J-B weld, etc? I could buy a new one for $82, BUT ... Thanks in advance.
Rob
06-09-2003 03:28:01
 Re: Governor leak in reply to Pj 8n Wy, 06-08-2003 22:25:11
That's a candidate for solder or brazing. If you don't have the experience for it you might find someone that does. A crack at that fitting can be filled with solder or a braze and then the hole cleaned out with a tap. A pro might do it for $20 or so if you run the tap, dunno. It would be an invisable repair done right.
