Normal Charge in Amps
Red Raider
06-10-2003 19:39:19
What is the normal output in amps at normal operating RPM for adequate charge but not to boil the battery. The tractor is a '41 9N with the cutout only.
Joel (SoCal 44's)
06-10-2003 21:16:19
 Re: Normal Charge in Amps in reply to Red Raider, 06-10-2003 19:39:19
Figure about 3 amps at half throttle. Hmmmm, wonder where Dell is??
Njoy
Joel's right . . . Dell
06-10-2003 22:54:19
 Re: Re: Normal Charge in Amps in reply to Joel (SoCal 44's), 06-10-2003 21:16:19
Red Raider..... ...about 3 amps at 1/2 throttle. Adjust charge rate with 3rd brush on endplate of genny..... ....Dell
Red Raider
06-11-2003 09:06:39
 Re: Re: Re: Normal Charge in Amps in reply to Joel's right . . . Dell, 06-10-2003 22:54:19
Thanks Dell and Joel. I will definitely have to turn back the plate to a lower charge. I was running 7 to 9 amps.
Big Bo
06-10-2003 20:17:51
Can't answer your question (although I would guess somewhere around 3-5 amps, normal load), but love your handle. That would be Texas Tech Red Raiders, I hope. I'm Big Tech fan from way back.
Red Raider
06-11-2003 09:04:38
 Re: Re: Normal Charge in Amps in reply to Big Bo , 06-10-2003 20:17:51
That would be right Big Bo. Thanks for the amp response.
