Found my pocket size Jeppessen slide rule the other day. You know, those E6b type that are round. Got the heading side refreshed. Now I am using the computing side to figger" If I want my water pump to deliver approx 1.5 gph. at a rate of "blank" rpm's, what size pulley should be on a 1725rpm, 1945 vintage maytag electric motor. Oh yea, the pulley on the pump is much larger, 'bout 12 inches, maybe 16, I think. Let's see: The formula was: driven pulley divided by rpm's X's driving pulley divided by gal. per hr. equalls: 3 inch pulley on the ole maytag Does this sound 'bout wright?
Now bout the belt length: driven pulley divided by pies of someth'n times driving pulley all over divided by , anyhow this will be close to the 4L056 class A bel t out there in the shed. Well at depth of 32 feet should provide adequate to fill one of my 55 gal drums, solar heated to temp of 96.5 F. This water, same as the water used to water the mules that were on this property during the 1st day's battle some time ago, should be adequate to shower with in the outhouse that I plan on constructing for in the back yard. By turning in my older brother, the local twsp. GAVE me a permit for my outhouse!~Have a great day?
Any formulas that are accurate for any of the computations above, please forward. John
