Order Ford 9N Parts Online
PTO Seal 1940 9N
Robert
06-13-2003 19:14:38
I am looking for a PTO seal for a 1940 9N, I can find them for newer model but not as old as 1940. Anyone have any ideas of a part number and where to get one???
Thanks
Jack
06-14-2003 11:23:51
 Re: PTO Seal 1940 9N in reply to Robert, 06-13-2003 19:14:38
Robert. I know the seals ARE available at a New Holland dealer. So you don't haffta spend $140 for a new assembly like Dell suggests. For $18, you can have it fixed. Here's some great info from Tyler(MD)out of the archives.
You saved me too
06-14-2003 18:38:43
 Re: Re: PTO Seal 1940 9N in reply to Jack, 06-14-2003 11:23:51
Thanks Jack, I would have been on my way to tractor supply Monday for a new $$$$ shaft, thanks for catching that major bad info, I think starting now I'll take what I hear from some "Guys" with a grain of salt !
souNdguy
06-15-2003 17:51:28
 Re: Re: Re: PTO Seal 1940 9N in reply to You saved me too, 06-14-2003 18:38:43
Having just checked with TSC, .. they don't carry the internal pto shaft for a 9n... that is what we are talking about right? Or am I missing something here?
Soundguy
souNdguy
06-14-2003 22:08:53
I doubt tsc would carry the pto shafts anyway...
Soundguy
They do
06-15-2003 05:27:43
 Re: Re: Re: Re: PTO Seal 1940 9N in reply to souNdguy, 06-14-2003 22:08:53
And luckly Jack posted the correct answer or I'd be padding tsc's pockets with lot's of my money because of Dell's wrong answer.
Been seeing alot of that lately?
Cliff in Mo
06-24-2003 07:41:05
 Re: Re: Re: Re: Re: PTO Seal 1940 9N in reply to They do, 06-15-2003 05:27:43
third party image
test picture or tractor
souNdguy
06-15-2003 17:48:29
I thought we were talking about the tractors pto shaft.. the one that drives the pump, etc.. if so, TSC -doesn't- carry it... If we are just talking about a generic pto shaft that goes from the tractor to the mower.. then ya.. they carry some.
I'm assuming that former ( tractor internal pto shaft ) is what dell was refering to.
Soundguy
Scott
06-14-2003 03:59:58
Your local New-Holland (was Ford) dealer still sells them part# 9N727.
sometimes . . . Dell (WA)
06-13-2003 19:29:22
Robert..... ....sometimes things just are NO LONGER AVAILABLE (NLA) and early 9N pto seals appear to be one of them.
If the leaking bothers you..... ..Byte the Bullett..... ..replace your OLD 1 1/8 PTO shaft assy with the MODERN 1 3/8 PTO shaft assy and you'll get new modern no leak pto seals and a stronger PTO shaft. Its a 15 minute 4-bolt drop-in job if you park your tractor front axle inna ditch so you don't have to drain 5 gals of hydro-tranny oil.
Arn't you lucky, your 9N's pto shaft is fully interchangeable with the later 8N's pto. And you don't need to use any adaptors anymore eather..... ....respectfully, Dell
