I overhauled the engine in my 8N. Today was supposed to be the big day to hear it run. Nope. Here's the problem. I can't time the distributor. (It's a sidemount) I've rebuilt many, many engines, but i've never run into this. In short, with the timing mark on the flywheel at 4 degrees BTC, and I set the points to open at just that location. Tighten the distributor down. Put the rotor on, but it doesn't line up with #1 plug wire. It's PAST the wire. If I turn the distributor to line up the rotor with #1 plug wire then the points are off. It sounds like the distributor is off a tooth, but if I move it one tooth over, I just end up with the same problem but in a different location.The cam seems to be timed right (I didn't change the cam or crank gears, so I used the timing marks on the gears.) When the flywheel timing mark is on zero, #1 piston is at top dead center and both the intake and exhaust valves are closed. So, I think the cam is timed correctly, but the distributor is driving me nuts! Any suggestions? Other than a can of gas and a match? (I'm just about to that point!) -AL
