RJ..... ...used to be, the 4-nipple crabcap, had molded sparkie numbers like this. upper left nipple = sparkie #1 lower left nipple = sparkie #2 notta problem sofar, eh? then pay attention it gets tricky here lower right nipple = sparkie #4 upper right nipple = sparkie #3 amazingly, the frontmount timing order 1,2,4,3 CCW.But you state..... "press the spring clip on the left side of the cap....and it smoothes out", thats a BIG CLUE. Gently stretch the springie-thingie underneath your frontmount coil for a more secure contact with your distributor feedthru. Note also, the #8 X 3/16 points mounting screws can wear out and loose their ability to stay tight and your points will loose their gap setting of 0.015" and cause sparkie problems too. You do know that you can remove your distributor's 2-bolts and work on it at the kitchen table, don't you? The distributor is driven by an off-set cam and can not be re-installed incorrectly. (unless you use a BIG hammer)..... .....respectfully, Dell
