Governor
roy
06-17-2003 15:20:42
My governor does not have an oil line going to it.I have a 40 9n does the governor receive oil from the cam?
Rob
06-17-2003 15:30:29
 Re: governor in reply to roy, 06-17-2003 15:20:42
Put one on there. If the gov doesn't have a port then drill and tap one to fit the carb elbow fitting (without the screen). Right out the center of the back. Run a steel line over to the bottom of the oil filter. Maybe you should get a pre-formed line to see just where everything should be.
What's the bottom of your oil filter connected to now?
