Order Ford 9N Parts Online
9N lift problems
Andy
01-09-2001 12:26:02
I can get the 3 point to go up and down with out a load. If fact it works fine for the back blade. However, When I hook up the 5" brush mower or the disc, the arms will lift with no problem but they get stuck in the up position. I have to get off and lift the implement slightly to get it to go down. The other thing that works is to put it in 1st gear and pop the clutch. What is going on and what do I need to do to fix it.
ZANE
01-09-2001 19:22:49
 Re: 9N lift problems in reply to Andy, 01-09-2001 12:26:02
third party image
If you should be having trouble with the lift not going down when the lever is moved to the down position I would suggest that while the inspection plate is off on the side of the lift housing you reach in and manually push the two levers that go into the oil in the reservoir and are connected to the control valve. The control valve sometimes sticks in the up position. If you should find that you can make it go down by pushing toward the front of the tractor internally on the control rods then you should drain the lift and pour about 5 gallons of clean kerosene through the lift with the drain open. It is best to pour it directly into the inspection hole. Let the kerosene that drains out sit for about 15 minutes and pour it through again leaving the portion that is in the bottom of the container to be discarded. This should have the residue in it that may have been causing the control valve to stick when it was carried into the control valve.
You should also inspect the spring that is connected between the front end of the ram cylinder of the lift to the knee portion of the control rods that go from the linkage at the top to the control valve in the bottom of the pump. This spring sometimes looses it tension from age and usage and must have enough tension on it to pull the control valve out when the lever is moved to the down position.
Steve W
01-09-2001 13:02:23
I'd call your local priest for an excorsism
.....or maybe Zane can help
