Speed control erratic and sluggish.
Rob
06-21-2003 06:34:26
I haven't paid any attention to my governor but lately this 2N was erratic and unloaded, max throttle and in high gear would gradually slow down, just a bit, and then suddenly speed up and then repeat maybe 2 or 3 times in 1,000 feet. You could hear the engine speed change.
I finally took the governor apart and added a shim (washer) to correct the spacing between the fork base and the washer. I was surprised to add more then .030 to bring it back to spec.
The big deal is that now the balls cannot move so far out on the race and fall into that worn, dented area. Basically the balls are now riding on new metal that is flat and smooth. It's as if the races are new. Races go for like $50+ btw.
I also shimmed up the lever assy so it won't bind and flop around. I think I added .006".
This was an easy job that only took a few minutes. It's all in the FO-4.
If you had to buy the shim stock and a thin washer it would cost what $5, maybe $2. It made a real difference in the tractor. It runs at a constant speed, the throttle is much tighter at the quadrant and it seems to respond faster to the throttle.
I'll replace the 4 balls soon as I get a chance. They go for $1.50 a set.
Just so you know.
