Hydraulic Pump Overhaul Parts
Rick
06-21-2003 14:15:36
I purchased a "complete" overhaul kit for my 8N hydraulic pump. I noticed, however, that no replacement parts were provided for the "intake valve" (part no.: 8N-968) and its associated parts, nor was a replacement provided for the "pump control valve assembly" (part no.: 8N-640). Are these parts available? If they are, should I go ahead and replace them since I'm already in the pump? Thanks in advance.
ZANE
06-21-2003 17:55:39
 Re: Hydraulic Pump Overhaul Parts in reply to Rick, 06-21-2003 14:15:36
These parts may or may not still be available from the Ford/New Holland dealer but it would be a rare circumstance indeed to need to repalce either of them. I have been working on these lift for fifty years and to this day have never had to replace any of the parts you mentioned. I have had to polish and hone the intake and exhaust valves and their spools but never repalced one and to my knowledge they didn't need it. Even if one or the other is worn some the position it takes when in operation will overcome any slight leakage caused be wear.
If it ain't broke don't fix it!
Zane
tc
10-21-2004 15:01:37
 Re: Re: Hydraulic Pump Overhaul Parts in reply to ZANE, 06-21-2003 17:55:39
my 9n hydraulic pump intake valve got broken and doesn"t seem to match any exploded views i"ve seen so far. mine has the hairpin on the end pointing to the rear of the tractor, and the bushing is tapered at one end. any available?
