Order Ford 9N Parts Online
9N brakes again
Rusty 2N
06-23-2003 18:50:39
This is not the first brake job I've done on these things. Seems to be the most common job on them though, sure seals & brakes. My 2N will lock up at the touch of the pedal. This one I have tightened the brakes up till the wheel wont turn then drive it out of the shop. Loaded tires, new everything but no stop. The man needs his tractor & being an older gent. after a couple strokes he don't have the strength to stand on them. I can stand on the brakes & it don't stop the wheel. I can take the drum off & watch the brakes work, all good there. mabe need to take the drums in to get them turned. Taking these loaded tires off & on is gonna get me in shape anyways. Gotta go through the steering on this piece together tractor also. it's a 9N 2N, 8N NAA,Model A front hubs, & Harry Ferguson steering arm on one side. one farmerized piece of equipment. ( Motor is 1950 8N). Well I did want to repair N's for cash, guess I got my wish. Careful what you wish for!!! Thanks for all your responses & any ideas are welcome. Play safe.
Dell (WA)
06-23-2003 21:54:22
 Re: 9N brakes again in reply to Rusty 2N, 06-23-2003 18:50:39
Rusty..... ...why do I get the impression that the leading shoe is NOT linking to the trailing shoe? That leading shoe puts mega-pressure onto the trailing shoe for self-energizing brakes and eazy stopping. Sounds like there is a slot that the brake shoe web is suppost to fit into, and its not in the slot..... ...Dell
Rob
06-23-2003 19:22:42
Did you take the glaze off the drum? 60 or 80 grit emery cloth and sand the glaze off that drum might make all the difference.
Rusty 2N
06-23-2003 20:10:46
 Re: Re: 9N brakes again in reply to Rob, 06-23-2003 19:22:42
Yep, beveled the edges, all the tricks I have picked up here & doing them & still no good grab. Thats why I'm askin here hoping someone had a old trick that I'm missing. This is hilly country so brakes are a much needed item here. Never had to get a drum off these turned before sounds scary $$ wise. Thank you for your time & thoughts.
