Order Ford 8N Parts Online
Early 8N proofmeter
paul B
06-25-2003 08:43:47
Can a proofmeter be added to a early 8N that does not have one? Is it just a matter of adding the guage, and cable, or do I have to change something else?
I just picked this tractor up, and it's my first, and it just seems like it would be easyer to use with one. Thanks.
Paul B
06-27-2003 04:14:11
 Re: early 8N proofmeter in reply to paul B, 06-25-2003 08:43:47
Well, I had a chance to check it out last night, no hook up on the gov. Think I will scrach that idea, unless I ever need a new one. Thanks for the tips.
Dell (WA)
06-25-2003 12:04:26
Paul..... ...Yes, you can change the dashpanel to late model 8N dashpanel $$$ for proofmeter mounting and yes, you can get the correct governor housing $$$ to drive the proofmeter gutts, and yes replacement proofmeters $$$ are available, and yes replacement proofmeter cables are available $$$.
...OR... you can get a watch battery operated transisorized LCD tachometer from some hot-rod place like JCWhitney for $20 and stickitt on your dashpanel..... .....Dell
Steve(OR)
06-25-2003 09:55:23
Check your governor housing. You may not need to replace yours.
I have a 50 8n without a proofmeter, but the governor has a cable socket with a cap over it. I believe the cap simply unscrews. It seems that in 1950 the new governor housings were ready before either the proofmeters or the redesigned instrument panels. Or maybe mine was just replaced with the newer housing.
Rob
06-25-2003 09:08:35
You need to get the $237 governor with the shaft and housing to connect the cable from the proofmeter.
