Easy Measurement of the Front Mount Ignition primary using the terminal Block. Ignition ON … points ON (closed).. Positive GroundTerminal Block: X = Term, ^^^^^^ = Ballast, letter = Ident. ----- ----- ----- ----- ----- ----- ----- ----- - (A) X ^^^^^^^^^ X (B) ..... ..... .X (C) ----- ----- ----- ----- ----- ----- ----- ----- - 1. Black Meter Probe connected to Term C , Red Meter Probe connected to Frame (ground) Results = ~ 6.5 Volts (battery) 2. Black Meter Probe Connected to Term C, Red Meter Probe connected to Term A
Results = If A has a wire connected to Ignition Switch, Voltage should be < 0.5V If A has a wire connected to Top of Coil, Voltage Should be > 3.5 Volts 3. Black Meter Probe Connected to Term C, Red Meter Probe connected to Term B Results = If B has a wire connected to Ignition Switch, Voltage should be < 0.5V If B has a wire connected to Top of Coil, Voltage Should be > 3.5 Volts 4. Black Meter Probe Connected to Term A, Red Meter Probe connected to B
Results = (Ballast Voltage Drop) ~ (about) 3 Volts is normal. Results with Points Open = 0 (zero) Volts If these Voltages are Correct the Voltage at the Top of The Coil will be ~ 2.8 Volts and you will have the "normal" ~ 3 amps @ saturation
Hope This Helps
