PTO Seal
Robert
06-26-2003 05:19:06
anyone have pic's or digrams of how to change the PTO seal for 1940 9N? I think I have everything to do this, well except a diagram or something to go by.....
Thanks
Jack
06-27-2003 02:58:53
 Re: PTO Seal in reply to Robert, 06-26-2003 05:19:06
Click the link:
Robert
06-26-2003 10:23:40
Well I got the PTO shaft out, and low and behold the PTO seal I was told on here "9n272" is wrong. The one one the tractor is a metal ring with several different seals inside that you must have to use a press to get out of the houseing. So now I have everything out and no part, and do you think I can find the correct one.....NO, no one around here seems to have, or can order one, that goes for my local ford dealer as well. So now it is back to the drawing board....
Scott
06-26-2003 16:21:59
 Re: Re: PTO Seal in reply to Robert, 06-26-2003 10:23:40
The original shaft would have a spring and pin to keep tension on the seal and the part# of the seal was 9N727 not 9N272, sounds like yours was upgraded the the one used after 1943, the seal is still available because it was used on hundreds of thousands of tractors but the new rubber seal is only 1/2 as thick as the old leather seal was because of technology.
Dell (WA)
06-26-2003 14:57:49
Robert..... ...when I first answered your 9N PTO seal post, I told you that the seal was NLA and to replace your entire PTO shaft with new and improved late model 1 3/8" PTO shaft from 8N and that it would fit perfectly in your 9N. YOUR CALL..... ...Dell
Ron from IL
06-26-2003 07:05:56
Robert,
It ain't rocket science. You can do it two different ways. The first: drain the transaxle fluid, remove the four bolts holding in the axle, slide out the shaft, replace the seal, and reverse the procedure. The second is the same as the first, except you park the tractor nose down in a ditch (to avoid draining the fluid), then procede with the rest of the steps.
Good luck!
Ron
p.s.--Do yourself a favor and buy an FO-4 manual. It'll pay for itself.
Robert
06-26-2003 07:10:34
 Re: Re: PTO Seal in reply to Ron from IL, 06-26-2003 07:05:56
Thanks, I wasn't sure of I had to pull the entire shaft or not via the moutning plate or not....
