Order Ford 8N Parts Online
8n timing
pat
06-26-2003 08:04:36
Put a timing light on my 51 8n last night. Marked the flyheel on the 4 degree spot. Started the tractor and could not find the mark. I had to move the distributor about an inch and a half clockwise to get on the mark. I believe this means it was retaded by a bunch. A'm I right.
How come she ran just fine if it was so retarded.
Dell (WA)
06-26-2003 09:13:25
 Re: 8n timing in reply to pat, 06-26-2003 08:04:36
Pat..... ...check your centrifical weights under your points plate. They may be stuck or have broke springs..... ..Dell
bg
06-26-2003 08:45:25
How's it running now? Did moving the distributor make it run better or worse or the same? Does it start easier, have any more power or what?
pat
06-26-2003 08:52:07
 Re: Re: 8n timing in reply to bg, 06-26-2003 08:45:25
I didn't have a chance to run the tractor around after timing it to see what difference it made. I will put her through the paces tonight and report back tomorrow.
