Order Ford 9N Parts Online
What year 9N
Robert
06-26-2003 10:25:44
I have a 9N, was under the assumption it was a 1940, the serial is *9N21852?* The ? apears to be either an I or T. Can anyone tell me what if wuld be from this info????
Thanks
john
06-26-2003 12:43:46
 Re: What year 9N in reply to Robert, 06-26-2003 10:25:44
you got yourself a 1945 2n
Robert
06-26-2003 11:00:38
The last number is an I definately, I used an acid method to raise the letter
pete--NY
06-26-2003 12:30:59
 Re: Re: What year 9N in reply to Robert, 06-26-2003 11:00:38
Hi Robert, What is the "acid method" Thanks, Pete--NY (I have a 9n with some very light numbers.)
tom
06-26-2003 10:42:19
Adam is correct. There would not, in most normal cases, be a letter after the number. The I is usually a 1. Of the 9N's I've seen or owned, the number one always looked alike a letter I.
If that's the case it is not a 40 model but into the 2N designation as Adam indicates.
Adam P
06-26-2003 10:34:58
Figuring that the "?" is a last digit, like a 1 or a 7,,, it would be a 1946 2N.
HTH
AP
