Hydraulic Pump Valve Chamber
Rick
06-28-2003 02:48:07
I'm trying to overhaul my 8N hydraulic pump, but I have not been able to remove the 4 small valve guide sockets at the bottom of the valve chambers. What is the trick/technique (assumming there is one) to get them out of there? Thanks in advance.
Hobo,NC
06-28-2003 05:14:54
 Re: Hydraulic Pump Valve Chamber in reply to Rick, 06-28-2003 02:48:07
I use a plastic pick that came with my sodiering iron. Its 1/4" ground down to look like a sraight blad screw driver. I push it into the seat and spray some carb cleaner and jiggle it till it works free. I do not think this part of the valve needs to come out. Its just a guide. But I did change it out on mine.
