Here ya go:
 Looks like a Christmas card....very pretty! Did you try to retype the URL? You had a period in front of the "u" (user ID) parameter and you needed an ampersand (&). Instead of retyping the URL, use copy and paste. When you get to the picture you want to show here, left click on its URL (web address in the "Address" box) one time to highlight it. Then, either right click on it and choose "Copy", or press CONTROL-C to do the same thing. Then, come back here to YT, put your cursor in the "Optional Image URL" text box and either right click your mouse and choose "Paste", or press CONTROL-V to do the same. Yes, you can imbed multiple image URL's in one message. You simply need to type the following HTML code anywhere in the Comments box, as often as you like. NOTE: this goes in the Comments box, not the "Optional Image URL" box: <center><img src=""></center> You need to insert the URL for each picture between the double quotes above. For example: blah blah blah...text here <center><img src="http://www.photopoint picture #1"></center> blah blah blah..... more text <center><img src="http://www.photopoint picture #2"></center> even MORE blah blah blah.....LOL <center><img src="http://www.photopoint picture #3"></center> Hope this helps..... ..... Ed '52 8N475798
