Order Ford 8N Parts Online
8N breather
Paul B
06-30-2003 09:36:04
I just picked up an early 8N and she is pumping a bit of oil. Now from reading the shop manual, it says to clean out the oil cap/ breather. Now this is plugged solid with crud. I am hoping this is my problem. Does this unit come apart to clean? I have it soaking now but it seems like it would be easyer if it came apart.
Paul
Lee
06-30-2003 14:29:13
 Re: 8N breather in reply to Paul B, 06-30-2003 09:36:04
If the tractor's been sitting a lot you may be lucky enough to have it improve on the blow-by from the crankcase with use. I bought a Jubilee this spring and it was puffing lotsa smoke out the breather cap like your 8N. The first couple times I used it I figured it was definitely going to need rings really soon. I found the more I used it the less it puffed out the breather. I guess the rings were stuck from sitting (since '98) so much and loosened up from running. It still "breathes" a little but nothing like it was originally. I'll keep my fingers crossed that yours will do the same. Good Luck, Lee
Paul B
06-30-2003 17:53:21
 Re: Re: 8N breather in reply to Lee, 06-30-2003 14:29:13
Thats what I am hoping. After I changed the oil, it got a little better. The breather cap was plugged solid. Thats got to be doing something to increse the oil burning. Wish me luck.
PloughNman
06-30-2003 12:59:47
Hey Paul-
It sounds like you have an original breather cap for the early 8N's and the 9N & 2N which has the front mount distributor, long oil fill tube on left side and the cap has a wire mesh inside along with an "X" or big cross stamped on top. It looks like these are assembled as a permanent unit-taking it apart might destroy the stamping. Manual says to just soak in kerosene and blow dry with air. I just soak mine in mineral spirits ( gas seems to take off the paint ) and use compressed air to blow out. The newer ones with the wing nut do come apart, but I don't think they fit right in the tube-too sloppy. I keep one old used cap for working and one NOS for show. I did notice last time that the wire mesh inside is getting pretty frumpy from blowing out, so I may switch to an old wing nut style for my work duties.
-Tim
Paul B
06-30-2003 13:20:32
 Re: Re: 8N breather in reply to PloughNman, 06-30-2003 12:59:47
Yup Tim, thats the one I have.I do have an early tractor, and it has the "X" and everything. It seemed to clean up pretty good, I had it soaking most of the day. Lets just hope thats my smoking problem. [at least SOME of it]
Paul B
Rob
06-30-2003 10:18:39
Not all come apart. Mine has a wing nut at the top center with a replacable hair element. There's another one just a bit bigger round then the tube and it doesn't break down.
You can get the wing nut cap and the hair elements on some of the internet parts houses.
Dell (WA)
06-30-2003 09:49:27
Paul..... ...ya know, I wouldn't mucka round trying to clean that oilpan breather cap when a new one is only $5..... ....Dell
Paul B
06-30-2003 09:51:49
 Re: Re: 8N breather in reply to Dell (WA), 06-30-2003 09:49:27
lol Ya but I do have a nice big safty clean tank here at work, and I am here anyways, so what the heck, I figure I will give it a try.
Paul
