The ORC does nothing to deal with sudden stoppage of the hog. The shear pin or slip clutch are supposed to take care of that. The ORC does prevent the rotational inertia of the hog from back-driving through the PTO gears and then attempting to turn the wheels. This avoids such problems as running over flower gardens, wive's cars, etc. Should the tractor strike something immovable like a tree, perhaps while the operator is looking backward at the hog, the inertia of the engine will try to drive the wheels, and the inertia of the hog will also try to drive the wheels. The most likely result is that the wheels harmlessly spin. The ORC would prevent the torque backfeed from the hog in this circumstance. Is this likely to damage the transmission? Any more than hitting a stump and suddenly stopping the engine? Personally, I don't see it. It won't hurt, but I don't view "saving the transmission" as the primary reason for the ORC. I damaged my ORC when I hit a big wad of fence wire with the hog. The ORC broke before the shear pin -- wasn't too pleased about that. I wanted to use the 9N, so I've been a bad boy and have been running the hog without the ORC. You need to plan ahead on stops and turns, and it isn't recommended. I get away with it in part because it is a 48 inch hog with less inertia than a 60 inch model. In the course of doing this, I have discovered one transmission related problem that does arise. Without an ORC, if you stall the hog against an obstacle while going up a hill, you can end up in a circumstance where the stuck hog tries to turn the transmission one way, and the weight of the tractor turns it the other. These opposing forces lock both the transmission and PTO in gear. Stepping on the clutch doesn't help. You can't get the transmission into neutral, nor disengage the PTO. You can't use the engine to pull yourself out of this mess, because the hog won't turn and the PTO is stuck in gear. If you yank on the shift levers in frustration, you might very well "damage the transmission". The only way out is to get a winch or another vehicle and pull the tractor forward (or lift up the hog and unjam it).
