Order Ford 8N Parts Online
8N no spark
norman cox
07-03-2003 19:39:33
Parked up the 8N but left ignition turned on. Following day wouldnt start and no spark. Could leaving the ignition turned on have caused coil (12Volt ) to burn out. All suggestions welcome.
scrub
07-03-2003 20:01:46
 Re: 8N no spark in reply to norman cox, 07-03-2003 19:39:33
It is most likely a case of burned up points. With the key on you have a continuous power applied to the coil. If the points happened to be closed when you parked it then...well no sparkies when you come back. Good luck.
Cant-tell
07-12-2003 16:09:02
 Re: Re: 8N no spark in reply to scrub, 07-03-2003 20:01:46
I Had the smame problem. Thanks for asking.
Rob
07-03-2003 19:57:39
I hear it gets the coil and the points.
souNdguy
07-03-2003 21:24:40
 Re: Re: 8N no spark in reply to Rob, 07-03-2003 19:57:39
Wouldn't be bad to check both... Though points are cheap and easy.. then if no spark.. try the coil.
If he has a dressing stone.. he might even try dressing the points just to check if spark returns.. then he would know whether coil was bad too. Either way.. a few bucks for points is the way to go in the end..imho
Soundguy
Allan C
07-03-2003 21:45:43
 Re: Re: Re: 8N no spark in reply to souNdguy, 07-03-2003 21:24:40
If I remember right there's also a resistor under the left side of the instrument panel that could fry. If you have no power to the coil, try there.
souNdguy
07-03-2003 21:52:32
 Re: Re: Re: Re: 8N no spark in reply to Allan C, 07-03-2003 21:45:43
True,, the resistor is a point to check, and the key switch as well.
Soundguy
