OT/Belt Dressing
R.M. In AL
07-05-2003 19:56:18
I posted a message yesterday asking for information on a good remendy for slipping belts on mowers etc.Since I did not recieve any information I figured you guys have the same problem but not a solution.Well I finally found somthing that really works good.For me anyway .It is a belt dressing made by Prestone and you can get it at Walmart.It comes in a small spray can for less than two bucks.It is somewhat sticky as it begins to dry and it holds the belt to the pulley good..Glad to pass this alone.Hope it helps someone...R.M. In AL.
souNdguy
07-05-2003 21:15:38
 Re: OT/Belt Dressing in reply to R.M. In AL, 07-05-2003 19:56:18
I've had some luck with plain old bar type soap, held against the belt, and have also been told to use candle wax by an old mechanic ( I didn't try the wax... )
I have used the -in-the-can- belt dressings... some work better than others.
I've found spraycan style carb cleaner will clean greasy/oily residue off the pullies real good... that and a new belt at the right tension seem to be the best way.
Soundguy
