Valve removal tools.
Rob
07-07-2003 15:38:59
third party image
These tools worked surprisingly well removing the valve assy.
The vertical cylinder shaped thing is a valve assy from the Ford flathead. The round bar coming from the right side is the end of an old tire iron that I modified to push down hard on the valve guide to move it far enough to remove the valve guide retainer. I beveled the end because it goes in at a small angle and I wanted to get real close to the valve stem. I took some off the tip of the iron for more room in the exhaust port and I notched the bottom side for that 'hook' so I can push the valve guide down hard. This design is like that screwdriver Zane describes but that tire iron might be more 'convincing' then a big screwdriver. The large flat bar is sold as a 'valve spring compressor' and that will put a lot of upwards push on the valve assy to get it removed from the block. It fits into the valve spring most anywhere. I use a large socket sitting on the edge of the valve chamber as a fulcrum. You might have to go back and forth a couple of times to work it loose after the retainer is out but it isn't hard to do with these tools.
Rob
07-08-2003 15:33:33
 Re: Valve removal tools. in reply to Rob, 07-07-2003 15:38:59
Wore out the tire iron before I got em all. I had to straighten the iron once and then that last stuborn exhaust valve just bends the now softer iron. So much for work brittle. Dang thing is flacid.
TSC had a 5-piece set of prybars for 10 bucks so I can attack that last valve with a higher caliber bar. The big one is 24" and it won't bend, I hope.
Found a brand new Craftsman C-style spring compressor in a pawn shop for $10. It let me remove ALL the bottom retainers in about 3 minutes.
ZANE
07-07-2003 19:25:04
Necessity is the mother of invention.
That looks like it would do the job.
To remove the valve assemblies after the horse shoe keeper is removed I just use that big old all steel GI issue screw driver to place against the bottom of the guide where the spring rests and drive them out with a hammer.
Rob
07-07-2003 19:37:47
 Re: Re: Valve removal tools. in reply to ZANE, 07-07-2003 19:25:04
Yep. The exhaust valve need beat some. I have a brass drift I like to use. Hard to get on that lip with the spring in there.
That tire iron is the right tool! I just lean on it and bounce about three or four times and POP! those exhuast valves move. No sweat.
Hey, these valves had ZERO lash. Opening early and closing late, every one. Two of the exhuaut valves were leaking/burnt. Compression was like 75. One went to 110-112 dry when I got it lapped and adjusted.
Other then the compression what is the symptoms of valves with no, and I mean zero, lash?
Low power? Backfire out the exhaust possible? Fouled plugs? Missing? Low compression? What? I never see anyone post about adjusting the valves. Bet more then a few N's need the valves adjusted. Go to long and you have burnt seats.
I'm on a run posting pics. I've got this 'parts pieces' thing working for me. Send me those pics of that pump and I'll post em.
