Left brake pedal removal
randee peel
07-10-2003 11:35:44
I have the tractor split and the sherman transmission visible on my NAA. I am trying to remove the left brake pedal to remove the shaft which will allow me to get at the transmission seal. I am unable to remove the left brake pedal from the shaft. It has it seems a shear pin which I cannot get at and I can't force the shaft out by hitting the end of the shaft.
Can someone tell me how to remove the pedal from the shaft?
Rob
07-10-2003 14:03:06
 Re: left brake pedal removal in reply to randee peel, 07-10-2003 11:35:44
Is that a tapered pin? If it is only one way it comes out. I'll go look at mine.
I don't see a pin. No pin in the parts book. Bolts.
The left brake pedal is on the right side. It has a bolt that sqeezes the pedal arm onto the keyed shaft.
randee peel
07-10-2003 15:55:41
 Re: Re: left brake pedal removal in reply to Rob, 07-10-2003 14:03:06
Rob, your probably right it is a keyed shaft but how do I remove the brake pedal. The key is not accessible.
Randee
Rob
07-10-2003 16:12:04
 Re: Re: Re: left brake pedal removal in reply to randee peel, 07-10-2003 15:55:41
That should be pretty easy. Remove the bolt and spread the arm with a wedge; ie, large screwdriver, tap it in there. A chisel would be better I guess. Just tap it in, you shouldn't have to spread it much. It comes loose and slips off the shaft then you will remove the key.
You aren't working on the pedal on the left side of the tranny are you? That's a different kettle of fish.
