I have to agree with Dell. Those ceramic resistors are tough cookies... I don't think I've ever 'burned' one out.. even the cheaper malaysain made radio shack ones. Tractor electrics are as simple as you get... usually only three-four circuits.. ignition, starting, charging, and lights. Check your wiring for a short. My guess is you have a wire touching ground somewhere ahead or behinf the resistor, and that is where the circuit is open ( if anywhere ). Do you get a voltage reading on the ignition switch side of the resistor? If so, that line is good. Do you get a voltage reading on the output side of the resistor? If so, then the resistor is good. ( check to make sure you didn't twist one of the legs off making it a 10 watt 1 ohm resistor again... ) Overall, with more resistance in the circuit.. there is less current flow... don't see how that could cause your problems unless you have a short somewhere. Follow those wires good. Run temporary ones as jumpers and disconnect the old ones as a test. At home I keep many varied lengths of pre-made jumpers with aligator clips.. makes these diagnostics easier. For your tests, you don't need anything that fancy. Just recreate your basic ignition circuit, bypassing everything, including switch... just start with the battery, whatever resistors you are using, and the coil... If everything is working, then start working backwards and start adding in componets to check.. like the switch, wiring blocks if used, etc... you will eventually find the component or wire that is causing the fault. Check your connections well, and make sure you arent grounding anything where it shouldnt be.. like an errant strand of wire sticking out from the primary connection on the coil, etc. let us know what you find. good luck Soundguy
