Order Ford 8N Parts Online
8n oil pan Gasket
Ron
07-18-2003 13:36:46
Has anyone changed the oil pan gasket on there 8n? Not sure how big of job i'm getting into.
Thanks Ron..... .
mike-ga
07-18-2003 16:31:51
 Re: 8n oil pan Gasket in reply to Ron, 07-18-2003 13:36:46
I just redid mine a couple months ago cause I had to drop the pan to fix oil pick up tube. It is not hard at all, just helps to have two people. I did all the work myself and it made it twice as hard. You need to take off the hood, of course block the tractor up behind motor/oil pan REAL good, take front end loose and move at least one side out of the way. I did not take my radiator hose off, just moved the front end forward-cause I had to get to 1 bolt that you have to move the front axle to get to. Make sure you take out ALL the bolts, the ones on the front I missed and wondered why the pan did not drop. As far as a gasket, no one in my area (and its farming/8n country) had one and everyone told me to use the blue rtv silicone which I have had a lot of experience with. I did and it worked great. Using a gasket is up to you, but you will probably have to order it.
Long story short-a pretty easy job in the shade with 2 people.
Mike
