Cylinder numbering?
Paul
07-19-2003 22:01:02
Are the 8N cylinders numbered from the front to back? I seem to have a pneumatic pocket in my brain... I pulled the distributor off in a bit of a frenzy since it was not firing, and failed to mark the wires. Now, I have a popping during a load, and even at idle. I figure I got a wire crossed. Any help is appreciated.
Thanks,
Paul in Texas...
souNdguy
07-19-2003 22:09:10
 Re: Cylinder numbering? in reply to Paul, 07-19-2003 22:01:02
cylinder towards the radiator is 1, then 2,3,4
On the side mount distribuitor, once you find 1, the rest of the wires are wired CCW.
the front mounts usually have the numbers designated and take into account the flop in the wires.
Firing order is 1243
good luck
Soundguy
Paul
07-20-2003 16:52:32
 Re: Re: Cylinder numbering? in reply to souNdguy, 07-19-2003 22:09:10
Thanks Soundguy, I figured it was from the front. I went out this A.M., and checked the distributor. Had the 2 and 3 backward. Changed them, and it runs great now. Wife says that if I don't take the blade off the back, she'll look out some day, and only see the top of my head. I just like to play on the stuff I once dreamed of...
