Middlebuster
Pitch
07-20-2003 17:45:06
Has anyone actually used a middle buster? I just bought one today and am not sure how to adjust it. I put it on with a long toplink,but it keeps tripping the draft control. I then shortened the toplink and I only get about 6" penetration. This is real hard packe clay. Maby I should just get a subsoiler tooth for it.
Tom A
07-21-2003 15:35:48
 Re: Middlebuster in reply to Pitch, 07-20-2003 17:45:06
Pitch:
I use the middlebuster all the time to lay out my garden (it's long and skinny; the rows are about 300') rows. If I want to put something in deep, like taters, I may make two passes. If your soil is really heavy clay or virgin sod you will probably have to do the same.
I've got a subsoiler, too. It is great to use every couple of years to improve drainage, but doesn't do much to prep the soil for planting anything.
Tom A
Dave 50 8n
07-20-2003 20:56:54
I dont' know what you mean by "tripping the draft control." Do you have a 9/2N?
I just hook mine (Gearmore Brand) up so it's pretty much vertical, drop it and go. I'll shear the pin once in a while, but it's supposed to do that.
I keep the "shovel head" on. I could take it off, but it works as is.
I think the deepest I can get is about 16-18", which is governed by the lift bars dropping to the lowest level.
You may have to water the ditch, let it set and go again.
Good luck!
Pitch
07-20-2003 21:21:20
 Re: Re: Middlebuster in reply to Dave 50 8n, 07-20-2003 20:56:54
I have '49 8N. What I mean by tripping the draft control is when it hits an especially hard spot the hydraulics lift as they are supposed to then resume their former depth resulting in a un uniform depth in the ditch
Dell (WA)
07-21-2003 06:00:19
 Re: Re: Re: Middlebuster in reply to Pitch, 07-20-2003 21:21:20
Pitch..... ....sounds like your draft control is working as it is supposed to, constant load on engine by raising your middlebuster when the going gets tuff. Since you have a 8N with the little "flush" handle under your seat, you can change from horizontal draft control to the vertical position control which should give you a constant depth. You may need to make several passes to be satisfied..... ..... Dell
