Order Ford 8N Parts Online
8n vs. 9n
Bob
07-21-2003 06:38:59
I am looking at buying a tractor to use around my lake lot (almost 4 acres) for mowing, dirt work, gravel spreading and other various odd jobs.
I would like to know the difference between an 8n and 9n. Also, I would like to hear what the advantages are over one or the other.
Any input or advice will be greatly appreciated. I know very little about tractors, but am a pretty fair shade tree mechanic when it comes to old cars or machinery.
Thanks!!!
'Ole Henry' (Va)
07-21-2003 13:14:03
 Re: 8n vs. 9n in reply to Bob, 07-21-2003 06:38:59
Bob, what the others have said. The biggest difference in my opinion is the 8N has an updated hydraulic system that is much easier to operate than either the 9 or 2N's. The earlier system was designed primarily for ground engaging implements (mainly plows)and operated either full down or full up, with no in between. The system was redesigned for the 8N' to allow the operator to adjust an implement to any position desired making it easier to operate above-ground implements (mowers & such).
My personal preference would be the 8N, but a lot of folks on the board are totally satisfied with the 9 and 2 N's.
Hope this helps, welcome to the N-crowd...John A
burk
07-21-2003 12:00:20
Check this website for a list of differences. It shows the evolution of the N series tractor. http://home.att.net/~jmsmith45/identify.htm
As time went by, Ford improved the tractor. For that reason, I held out until I found a later model 8n. I got an early '52, but I wish I had found a late '52 with the lower reverse gear. However, I'm happy with what I've got. The main reason I wanted a late model 8n was for the side mount distributor. The first thing I did was install an electronic ignition. Just my personal preference.
Good luck with your search. You will find that many people don't know an 8n from a 9n. The place I bought my tractor from told me it was a 9n. Luckily I had done my homework and knew what what it was.
bg
07-21-2003 10:09:49
8N has 4-speed tranny, 9n has a 3, 8N has position control(usefull for bush-hogging, grading), 9N does not, 8N has brakes both on right side, improved brakes, 9N has left and right on opposite sides of tranny, 8N later models have side-mount distributor, 9N and early 8N have front-mount, which is prone to moisture problems and breakage from worn front axle pivot. Other than that the tractors are about the same. No live PTO, no external hydraulics. The 8N would be my choice over a 9N. I'd rather have a later NAA, 100-series or even a 1000-series.
