Jubilee won't start AGAIN!!!
Randy/MI
07-21-2003 06:51:36
After leaving my Jubilee in the woods all last winter because I couldn't get her running, I replaced plugs, coil, condenser, points, battery and rebuilt the carb. early this spring after the snow melted. I had her running just fine thanks to the help of this board.
Now she has no spark again. I replaced the ignition switch and still nothing. When I short out the points to the side of the distributer I see spark but nowhere else.
Any advice would be appreciated...
Jerry 9AL)
07-21-2003 18:39:25
 Re: Jubilee won't start AGAIN!!! in reply to Randy/MI, 07-21-2003 06:51:36
I've had a problem with mice chewing away the insulation on wiring. i've had two occasions now where field mice I assume have chewed on wires and I have had starting difficulties. I recently had a problem where I couldn't start it due to the wire from the starter button to the solenoid had been chewed in two.
bg
07-21-2003 10:12:10
Check the primary wire terminal insulator on the insideof the distributor housing. Also see if the copper strip that attaches to the points is still intact.
