10 ohms didn't do it
8NJAY
07-21-2003 17:02:11
I put a 10 ohm 10W resistor in the P1 line of my alt. When I turned the switch off the tractor kept running. Two 10 ohm's worked. Any thoughts out there? No marker lights please.
jonboy
07-23-2003 11:03:06
 Re: 10 ohms didn't do it in reply to 8NJAY, 07-21-2003 17:02:11
Why screw with all the resistor/lamp stuff at all.
Industry #14255 Hitachi. Use the L and S terminals to go to your IGN and ACC terminals. Simple is best. The alternator was a new rebuild from the local recycler. Marked as for an '86 Subaru as I recall. Also uses the original generator bracket ('52 8N) with 7.5" of 3/8-16" redi-bolt.
jonboy
Jim WI
07-22-2003 11:22:27
Check the ignition circuit to make sure the correct resistor(s) are present.
David - OR
07-21-2003 18:23:27
A 1N4001 or 1N5401 diode in series with a 10 ohm resistor is what I use. Put the cathode end towards the alternator. Tie the anode to the resistor. Tie the resistor to switched battery voltage. This offers a better solution than any selection of resistors:
1) A 10 ohm resistor ensures a high enough field current to turn the alternator on by 600 RPM or so.
2) The diode completely blocks back-flow current so there is no chance of run-on.
3) For extra credit, you can put a small idiot light in parallel with the 10 ohm resistor. It can even be a little dinky LED that normally would not work for excitation purposes.
And if you really want to know what's going on, replace the ammeter with a $12.00 voltmeter. Connect the (+)side of the voltmeter to the output of the ignition switch. Tie the internal light of the voltmeter to this point too. This makes it easy to diagnose the infamous "ignition switch goes bad" problem, and the lighted voltmeter reminds you that the key is on -- should you ever stall the tractor or run out of gas, etc.
You can get by with just a diode and no resistor, but the resistor adds a measure of safety and longevity to both the alternator and the diode.
JimNC
07-21-2003 18:21:32
Why not use a diode? Works real good on the logging equipment I work on. The machines come from the factory like this. I can't remember the exactly which way it is wired but I will look at the schematics Tues. and let ya know if ya want.
Jim
