Steering sector warped. Can I ???
Rick
07-25-2003 17:11:09
The steering sectors on my 9N are warped in such a manner that the mesh with the pinion is pretty good at the ends but have a fair amount of play in the center. The teeth on both the sectors and the pinion are in good condition. It is not to the point where mesh is lost BUT there is some play that I would like to improve.
Has anyone tried straigntening out these sectors with some heat and persuasion?
Jack
07-25-2003 22:13:41
 Re: Steering sector warped. Can I ??? in reply to Rick, 07-25-2003 17:11:09
Are you sure they're warped? Sector gears in the 9N are prone to wear in the "straight ahead position" which is in the middle of the gears. If they're indeed warped, can you find a happy medium buy adding some outer thrust washers to mesh better with the pinion?
Jack
